pulled side panel fan wire out of controller
sgxmodz
78
http://www.amazon.co.uk/gp/aw/d/B0071KZNUY/ref=mp_s_a_1_2?qid=1395599008&sr=8-2&pi=AC_SX110_SY165
thats my case and on the side panel thrre are 2 fans that connect the a mini motherboard so I can turn them off pressing the button on the side panel.
bassically I opened my side panel and pulled a black and red wire out of 2 small metal sockets. The red and black wire is the molex connecter wire is there any way to fix this?
Will there be a big diffrence in temps? As im worried my pc will over heat my gpu never got over 60degrees and the only fans I have now is the front,cpu,psu,and 2 on the gpu
The wires in the molex should have pins on them. Did the wires get pulled out of that, so bare wires are showing, or did the pins come out of the molex?
http://members.optusnet.com.au/~thw01f//molex%20pin%20remover/pins_removed.jpg
If they came out how that picture looks, it could be possible to simply reinsert them, if the clips on them are still functional (meaning they will hold in place and not come out when you try to plug them into the PSU molex).
The wiring should be red/black/black/yellow, which should be easy enough since only one black came out.
Its not the molex end its the other end that is stripped. The stripped wire is supposed to go to a converter witch converts 2 chasi fans into a molexf I fixed it by just loosly putting the stripped wires back in the holes until I get so welding gear for it thank you for trying to help
Welding gear? Honestly seems like hardcore modding to me haha.
