Hello there, and sorry for my bad english!
EDIT: I saw here that it would be better to plug the pump onto the SYS_FAN, and run the pump at full speed for better flow and constant cooling : anyone could confirm ? If not so, I think I will plug both PUMP and Radiator Fan to CPU_FAN to be sure.
Today I built my first ITX config, and I have some questions about my AIO :
My mobo is a Gigabyte - Z390 I AORUS PRO WIFI and my AIO is a Cooler Master - MasterLiquid ML120R
I read 10 times all of the documentations, asked on discord and checked on forums, but I can't find any answers.
My mobo have 3 fans connector : 1x CPU_FAN and 2x SYS_FAN, my question is, what do I need to connect to CPU_FAN ?
-> The pump + the fan on the radiator (with a splitter) ?
-> Only the pump ?
-> Only the fan on the radiator ?
Some screenshot :
btw, I have 4 fans, all Corsair LL120RGB, RGB pin's of those are connected to the Node Pro, and the RGB pin of the AIO is connected right onto the motherboard.
Thanks for your answers!
-> Only the pump ?
Some screenshot :
