I need some opinions here, mostly because I'm very short on time these days and would rather avoid the usual experimentation.
A few weeks ago my old Swiftech MCP655 started making a horrible racket. Just suddenly, out of the blue, like it was trying to drill it's way out of the XSPC dual bay res it's in. I figured it had finally died, and ordered up a Koolance PMP-450, just because it was the best price.
So, the other day I finally found time to do the swap. I pulled the old pump out, and sure enough the impeller felt rough and grindy when spun, and I could see wear/abrasion at the bottom of the bowl the impeller floats in. I put the new pump in.
Did my best to fill the loop before turning anything on, but it seemed like it wasn't filling like it should. Still, the bay res was full so I turned on the pump.... and the water didn't seem to move. I could feel the pump working. So, I cranked up the pump most of the way until it started whining. Still no bubbles or air moving out of the system... could it really simply be full? Maybe I got all the air out before I turned on the pump?
Two minutes later the new pump started making a similar loud noise. I unplugged everything and today I finally found time to pull the new pump out. IT SEEMS fine still.
So what is going on here? Do you think my loop could be actually plugged up somewhere? I want opinions before I spend the rest of my only full day off breaking everything down.
