Question Pump RGB not turning on with corsair h100i rg platinum
Jan 14, 2020
6
The fans on the cooler are working (they light up) but the pump rgb doesn't seem to be working for some reason. I plugged in the USB cable and everything.
Schlachtwolf
Proper
Jun 22, 2019
166
28
140
19
What Mobo do you have, that will tell me what you need for RGB software. On the Asus boards for example the Aura app allow you to calibrate the RGB headers to get the RGB on the pump working. I recently installed a Deepcool 360V2 and had to recalibrate the RGB header to get it shining (lovely cool blue).
MSI etc have their own apps for this too. Also make sure your RGB header is installed the right way round !!!
Cheers
Jan 14, 2020
6
Cheers
I have a ASrock b450m a/c
Schlachtwolf
Proper
Jun 22, 2019
166
28
140
19
Did you download the software? Are you sure the right cable is connected to the RGB header and on securely?
Have you tried the Corsair iCue RGB controller, maybe the Corsair pump is not compatible with ASRock sync, Corsair also has had RGB issues with MSI boards in the past.
Mtop
Proper
Nov 21, 2019
146
7
Fans for radiator should display same color as pump.
Verify your wiring, look for damage to wires going to pump.
If new return for replacement. If you haven't run Icue try prior to returning unit.
