Purple Screen, Audio not working and Minecraft not Rendering properly after installing GTX 750 TI Graphics Card?
crockettguy1
Hello,
I installed my new graphics card today (Nvidia GeForce GTX 750 TI)and I have had many issues with it.
Minecraft shows a strange rendering issue like the one's below.
fCpRAsY,dlhxGoK
fCpRAsY,dlhxGoK
Audio aso isn't working but is being recognised as working by the computer and the Screen is purple tinted in colour. I am also using a riser cable and Windows 7.
Thanks
- crockettguy1
1. Make sure your video card is properly seated into the motherboard.
2. Make sure 3D anaglyph is off in Minecraft.
3. Uninstall the audio and video drivers and reinstall the audio from your motherboard mfg website and video from the NVidia website.
4. What input are you using non your graphics card?
5. What is your CPU and Motherboard model?
Dude I guess this should probably be a driver issue since you mentioned you installed a new card but didnt install new drivers so if you are still running the older drivers uninstall them and download the nvidia drivers for the 750 Ti and do the same for the audio I would recommend realtek audio drivers as a bonus though ! Oh and also check the connections if the above does not work just in case
Latest posts
