Push-Pull is pretty.. useless. Theoretically it shouldn't give you any better temperatures. Think about it, pulling in air that's already being pushed? The fans can only pull as much air that's being pushed by the other fans.
Same with positive air pressure... How should that give me better ambient temperatures? Wouldn't the best configuration be to have all my fans blowing fresh air in my case and have vents at the top for the hot air to escape?
Why should positive air pressure reduce dust in my case? The air (carrying dust) is passing through several components before reaching the exhaust.
I've also wondered why the standard tower case design is still around. Take a close look, its horrible for airflow/cooling. There are corners, things blocking air flow, wires, etc.
I'm not being an asshole either, I just want someone to prove me wrong so I can stop thinking about it 😛
Thanks for reading my rambling
