Hello everyone!
I have this issue where I cannot put both fans in push pull set up for my corsair H80i v2, I can only fit one but I think temps of my CPU get quite high whenever under load. I have a clearance of 1.6cm so I think i can fit a 120mm x 15mm, I have done some search and i came up with noctua nf-a12x15 pwm. If I set that as pull, would it improve my CPU temps? Any suggestions are appreciated. Thanks!
PUSH:
Corsair SP120L
Fan Airflow
70.69 CFM
Fan Static Pressure
4.65 mm-H2O
Fan Speed
2435 RPM
PULL:
Noctua nf-a12x15
Fan Airflow
55.4 CFM
Fan Static Pressure
1.53 mm-H2O
Fan Speed
1850 RPM
PUSH:
Corsair SP120L
Fan Airflow
70.69 CFM
Fan Static Pressure
4.65 mm-H2O
Fan Speed
2435 RPM
PULL:
Noctua nf-a12x15
Fan Airflow
55.4 CFM
Fan Static Pressure
1.53 mm-H2O
Fan Speed
1850 RPM
