Push pull with Noctua CPU cooler
Andromendous
195
Hey all, I was hoping someone would know what fan I would need to get if I wanted to add one to this cpu cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608041&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I would like it to be the same as the fan that comes with the cooler, but I cant seem to find the exact same one. Does anybody know? and would I need a special cable so they work togeather, or a Y cable that I plug both fans into, then into the cpu fan header?
Thanks for any help.
Ok, thank your. I just noticed that my MB has 2 cpu fan headers, so I think I might use a Y cable for the two cooler fans, then plug the back exhaust fan into the other cpu header for maximum cooling.
