So I dug through my things and found all the corsair fans that came with my radiator, as I use fractal design fans on those. Now if I wanted to do a push-pull on my radiators, what happens if both fans have different RPM's and CFM ratings? Would it be better for the fan that has more CFM as the push or the pull...? Not only am I asking this question in regard to radiators but also about the whole case in general, do you want more CFM push in the front of the case or more CFM pulling out from the top and back?
Also, for radiators, what if you had both fans pointed towards each other, so like.. push push?
