So I am currently pricing up a build that will consist of:
2 x Watercool MO-RA3 420 Core LCs
1 x 4770k (already own)
1 x Asus Maximus VI Extreme
Along with other components, but this is not necessary since the only part that is a concern to me is how well the motherboard will perform with extremely high voltage, along with the CPU.
I will not be 'pussy footing around' with the volts, but do want a semi-clear idea of how high I can expect to push the voltage before the CPU will likely die on startup.
I suspect high voltages will degrade the CPU lifecycle. I don't care for this CPU to last anything longer than a single year, it'll be at 100% load for all that time, at 5.4GHz+ with many volts going through.
Please note:
- The radiators will be cooling multiple systems at once.
- The motherbord will be watercooled.
- The CPU is already delidded with the vice method. I will not use the IHS, the CPU waterblock will sit directly onto the die.
- I am sure you have gathered if you have read this far, this isn't for your average PC build. The CPU I was given/swapped for a graphics card I no longer used, I have no interest in the price I could recieve for a pre-owned modified CPU.
Any recommendations on voltages will be appreciated!
Please note:
