ISP's modem: Telco 2141
that plugs directly into my firewall which is a SonicWall NSA 220.
Speeds are great, 100up/100down.
When I place a dummy, gigabit switch between the Telco 2141 and the firewall's WAN port, my speeds drop dramatically. Somewhere around 18down/15up.
The switches that I've tried: Netgear GS108, Netgear GS605v5 and Amped RTA15 (only using ethernet ports on back to bypass router, etc.) All have the same results but the speeds do vary slightly, however still much less than 100/100.
When the switch was installed between the modem and firewall, I assigned my laptop a static IP that was given to us by ISP and plugged directly into the switch (this bypasses my firewall) and my speeds were still degraded. I'm led to believe that the problem is with my ISP's modem and/or the switches that I'm using.
Can anyone offer some insight as to why or what is causing my bandwidth to drop so much after installing a dummy gigabit switch?
Many thanks in advance!
