PWM Fan Connector
cuzz4_life
11
So I currently have a Arctic B350 motherboard and the Phantek Enthoo Pro. I currently have the fan hub connected into my motherbaords pump fan connector. In the future I plan to upgrade my CPU cooler to a AIO but most, if not all AIO, use the pump fan. So where would I plug my fan hub when I get the AIO?
No problem.
1) The power supply should have SATA cables. The ones used for powering the SATA drives.
2) Yes, it's an option. Another option would be connecting all case fans to the motherboard, and not using the hub, since enough headers on the motherboard.
3) No negative effect.
Ok so I looked it up and my Motherboard has a Chassis Intrusion Connector, but that just a two pin. I have a open Front Panel Connector, will that work for my fan hub?
So the fan hub can run off of just a single 4 pin fan connector? I thought that those weren't powerful enough to handle multiple fan since they don't output enough volts to each fan.
Well my Enthoo Pro came with all my fans connected to the fan hub and a 4 pin connector to connect to my motherboard. Like I stated I just don't know where to plug it in the AIO when I upgrade.
Ok this just opened up more questions for me,
1) my power supply doesn't have one of those sata inputs so I can't put that in for that
2) if I plug the fan hub to the spu fan header then can I plug my cpu fan into the fan hub and it'll get enough power to keep my cpu cool?
3) how will this effect all the fans connected my fan hub?
PS: thank you for answering all my mundane questions.
No problem.
