UberCanuber :
I am buying three 4 pin PWM fans all exactly the same and was wondering if I can run them and control them from a single 4 pin output off my motherboard by using something like
this
Well, yes, you can. There's one little detail though.
Since one of the wires in a standard fan connector is a RPM feedback wire, you cannot just connect RPM wires from all four fans back to the motherboard. This will completely screw up the RPM feedback and make it meaningless.
For this reason, as you can see yourself in the zoomed picture, the splitter takes RPM feedback from only one fan of the four. That means that you will have one "master" fan, whose RPM feedback signal will govern the motherboard's speed control logic (and PWM signal) for all four fans. With four identical fans this should not be an issue. Although it might be a good idea to think carefully where you place the "master" fan inside the case.
A failure of "master" fan will typically ruin the operation of all other fans sitting on the same connector, since the RPM feedback will cease. (Depends on how the motherboard will react to missing RPM signal, besides raising an alarm)
And if one day you decide to replace some of these fans with different kind (probably not a very good idea, since all fans will receive the same PWM signal, but might work), you have to choose the "master" fan with care.
