Hello, I have been wondering, is it possible to have a set of pwm case fans that are able to turn off completetly at 0rpm? just like gpu fans?
I mean, its nice to always have fans running at certain speeds, but what if the computer with its cooling solutions is able tu have no fans running at idle and mantain acceptable temps?
All I want to know is if its possible to do this, to be able to run the fans at 0rpm using a fan curve, and if so how ? I have tried on my motherboard from changing the fan curves with the asrock utiltiy to speedfan but it never works, setting any curve to 0% will just pump up the fans to 100% speed. Is there any piece of hardware that would help me do this ? or will I be only able to do this using 3 pin fans as my motherboard is able to regulate voltage on 3 pin fans which means fans can be turned off if they are 3 pin.
I know that there are temperature concerns but again, this is just to set up a fan curve that when the pc is idling at lowest temp, it brings teh fans down to a stop as to be silent completely and then ramp up the fans again if the computer goes above certain temperature.
Thanks for taking your time in answering or reading here.
