RIght now I've got two 92mm fans running from a single PWM header on my motherboard via a PWM splitter. I'm pretty sure that PWM header has enough power to run both fans at max speed, but at what point will it not have enough juice? In another system that I worked on, I used the NZXT 10 port fan splitter, and it was powered via a 3pin connection. I had 5 fans attached to it, and I can tell that the fans were turning slower than normal. So what is the threshold of chaining fans off of a single header? How many is too many?
