Pwm hub question
jonathanlin
4
I plan on building my first pc and it's going to be a mini itx. I'm thinking about adding a pwm hub so I can improve airflow. Am I able to add the hub without having to tweak any settings and having all my fans run at stock speeds? I don't have a interest in over clocking, thank you!
I'm looking to get either the Asus b250i or Asus z270i. Both of these motherboards only have 2 fan headers from what I can see and only one of the headers support pwm, which is the CPU fan header. How would I run this connection? Thank you!!!
Connect the cpu cooler to the cpu fan. CONNECT THE hub to the other pwm header
I was looking at the manual online and I only saw pwm on the CPU header. So as long as there's 4 pins there's support for pwm? After I connect the pins I don't need to connect the 12v sata power anymore correct? I'm still learning, thank you!!! :)
