PWM in Asus x99 Deluxe 2 help
YMANGT
Commendable
Nov 24, 2016
12
i am looking forward to buy the new x99 asus deluxe 2 which i heard comes wiht a fan controller that can house up to 9 fans, i am getting 6 ML120 Pro White Led and i heard that you have to use them in PWM in order for them to levitate properly and for them to gain the 12 volts needed. so my question is does the fan controller that comes with the Mobo has PWM, if not then what fan controllers can i buy that can have PWM. Fan controller or hub. Thank you.
https://www.asus.com/us/Motherboards/X99-DELUXE-II/specifications/
Every 4-pin fan header is PWM capable.
The board also has some fan controllers, a card, and software for fan control. It's up to you to figure out how that will play with your substantial investment in the Corsair ML120s.
The Corsair ML series fans require the Corsair Fan controller and multiple fans require the Fan controller hub.
PWM regulation (on the motherboard, or in a fan controller/hub) regulates fan speed at 12V constant. So that won't be an issue if you connect your fans directly to any PWM fan header, but you won't be able to coordinate them without the corsair add-on stuff.
