PWR Fan 100 %
Foodrichie
26
Hello ppl, I want to ask about connectors 1 x 4 and 1 x 3. I bought new cooler that have 1 x 3 pin connector so I can use and plug it only for PWR fan one. Now the cooler spins 100 % and makes horrible sound. Does the PWR fan connection should damage my ASUS M5A97 PRO mobo? Original cooler had 4 pin connection and that was connected to the CPU Fan connector(s) (4 -pin).
- The connection is Processor cooler, but the temperatures seems okay.
CPU
AMD Phenom II X4 960T 24 °C
Thuban 45nm Technology
RAM
4,00GB Dual-Channel DDR3 @ 802MHz (9-9-9-24)
Motherboard
ASUSTeK COMPUTER INC. M5A97 PRO (Socket 942) 30 °C
Graphics
HP w2007 (1680x1050@59Hz)
1023MB NVIDIA GeForce GTX 560 (ASUStek Computer Inc) 34 °C
Storage
698GB Seagate ST375052 8AS SATA Disk Device (SATA) 31 °C
Typically, the PWR FAN header is designed for PSUs that have a separate fan cable. Usually the MB BIOS has no control for that header to vary the voltage for speed control. It always runs at +12V, or full speed. If you can, plug the fan into the 3-wire CHA FAN header. That one usually has voltage control for speed. The 4 pin CHA FAN header probably used PWM control to vary the speed and won't provide any voltage control needed for 3 wire fans.
