Q code b2 and vga light
Apr 12, 2017
6
Hi so i've got a pretty big problem
When i starting up my PC I have a b2 q code on motherboard and white VGA led
My specs
Intel core i5 6500
Ram hyperx fury ddr4 2133mhz 1x8gb
Gpu sapphire rx 480 nitro + 8gb OC
Power supply corsair vs 650
Motherboard asus maximus VIII ranger z170
And a cpu cooler silentiumpc spartan 3 pro
I tryed to update bios
Set graphic card to othe pci slots
Set ram in other pci slots
Clear cmos
And its still not working
Looks like your motherboard can't recognize GPU. Maybe GPU is faulty. It would help if you could check it at another computer. If you can't - it seems the rest of your machine is working well, so I would RMA the GPU.
when i remove gpu the pc normally starts up but i can not check it with another GPU 🙁
ok i found it and i have two options to gpu- IGFX or PGE its so strange because the description is to selet between pcie/igfx/pge and i dont have the first option
it was set to auto
when i set igfx and attached the gpu, the p boot normally but the hdmi cable was in the motherboard when i put it in the graphics card it has no signal and the pc cant read the temperatures and the driver not work, when i set to pge it doing like i was writing first vga light, b2 qcode no display
OK thanks for help
