[Q] How Replace Stock Power Supply with new [HP DV5800 Small factory]
Swarmachine
25
I have a stock power supply STOCK SUPPLY AMAZON and I want to USE an unused graphic card slot with " NVIDIA 210 " (and I have been missing wot - cos I have only 240w (from stock) And Requirement is for video card from 250w to 300w. ) so which replace power supply into?
*include*
Need salers link to NEW Power supply for changing stock power supply
to me was option Select of nivida 210 or 610 Forum Post#
* there is an empty graphic slot - cause now I'm using an integrated video card
* and don't know which power supply is the best for fit 🙁
Well, the GT210 is still below the minimum system requirements for what you're trying to do, so I would go with the GT 610. It only uses up to 29 watts of power, so it *should* still run on your 240 watt PSU (no guarantees, though). Power supply requirements are often inflated to make sure a system is sufficient to power it.
-Wolf sends
That is a proprietary power supply and unless HP provides an upgrade for that system, there is no update possible. I would ask what it is you are attempting to do with the proposed graphic card updates as neither card is really much better than the on-board graphics you already use.
-Wolf sends
Having issues with graphic card and directX 9.0 (Q33 Chipest)
"Dxdiag shows that there could problem preaching to show 'directshow' at last time then this tool was used, do you want skip? "
(then I click yes tool restarts and same issue appears , after second click yes tool is shutdowned)
...anyway I'm trying to run an run software which doesn't requirements very high minimal requirement
*Video Card: GeForce 6800 / ATI HD X2400 XT with 256 MB RAM & compatible with DirectX9.0c
Sound: Compatible with DirectX9.0c
this is spec of Q33 im running on 64 bits.
*Application has failed to start becouse no appropriate graphics hardware acceleration is available or it it turned off*
-Wolf sends
thank you for well good opinion, but last question: IS Gigabyte Radeon HD5450 GOOD for 240w?
I've read some positive reviews the Radeon HD 7750 Low Profile can run on a 240 Watt PSU or lower.
While you would probably be ok with the HD 5450 and others seem to say that an HD 7750 will likely work, I wouldn't recommend either as I don't think the power supply would handle it successfully and if that goes, you will need to find a replacement power supply and still need to get a lower powered card.
-Wolf sends
