Archived from groups: comp.sys.ibm.pc.hardware.video,comp.sys.ibm.pc.hardware.misc (
More info?)
In comp.sys.ibm.pc.hardware.misc A. Toprak <topraka@gmail.com> wrote:
> I need to use an old monochrome PC with a new color monitor.
> I am planning to use a DB15 to DB9 adapter.
> I want to make sure that this would work, I do not want to destroy anything!
> Any comments?
What kind of graphics card? The problem is that most modern monitors
expect at least VGA refresh rates, i.e. 31.5kHz horizontal and
60Hz vertical refresh rate. If they get less, most should not be
damaged, but you never know. They will not give you a good image
though. The computer should not be in any danger.
If your adapter is actually very old color (CGA) then you
might be out of luck, as this uses 15kHz/60Hz television frequency.
Most modern monitors cannot handle that. I think the same is true
for MGA and Hercules.
EGA timing is 25kHz/??, still too low for most modern monitors, but
you might get a readable image.
VGA timing is 31.5kHz/60Hz, any modern monitor can handle that.
Why not try to get an old ISA-bus VGA card from a scap-pile
somewhere? It should work with a new monitor.
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
