Hi guys, I'll be getting a Zalman Reserator 1 v2 along with the 8800GTX VGA water block for free. I don't know if I should loop both the CPU and GPU. Wouldnt I void the warranty on my GPU if I remove the stock fan? Is it worth it to water cool the 8800GTX? I know that card heats up like a mother.
Please check out my system on my signature. Would it be possible to overclock to 3.8-4GHz after watercooling the CPU? If so, would it be safe running it 24/7?
Your advice are greatly appreciated.
