Hi All,
First time over-clocker here. Been reading up and found some settings that seemed to work for me:
RAM: 2 kits of OCZ: Newegg.com - OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2RPR10664GK - Desktop Memory
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8x
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 400
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 400Mhx
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 700
PCI Express Clock Drive.................: <<< 700
CPU Clock Skew (ps)....................: <<< 0
MCH Clock Skew (ps)...................: <<< 0
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 400
System Memory Multiplier ..............: 2.66D
Memory Frequency (Mhz) ..............: 1066
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15
Set all Suggested below to highest Values first. Then later you can lower, one at a time,
testing as you go
Advanced Timing Control
tRRD..........................................AUTO
tWTR..........................................AUTO
tWR............................................AUTO
tRFC...........................................54
tRTP...........................................AUTO
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength 1066
Channel A
Static tRead Value.........................:10
tRD Phase0 Adjustment...................:Auto <<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
CPU
CPU Vcore….……….........................:1.31250V
CPU Termination…..... 1.200V*.......: 1.240V<< If overclocking Please set to stock, Auto
overvolts this way to much. Optimal range for overclock would be 1.2-1.5 depending on Vcore, try
to keep at least .1 under vcore. Auto is fine if not overclocking
CPU PLL…………………....1.500V*.......: 1.500V<< If overclocking Please set to stock, Auto overvolts
this way to much. Optimal range for overclock would be 1.5-1.65. Auto is fine if not
overclocking 1.500V
CPU Referen.…………....,,0.760V.....:AUTO
CPU Reference2………,,0.800V*.......:AUTOcorrectly
MCH/ICH
MCH Core…………….....1.100V...........: << AUTO
MCH Reference….…….0.760V...........; <<< AUTO
MCH/DRAM Ref.…......0.900V...........: <<< Leave
ICH I/O……………….....1.500V............: <<< Leave
ICH Core…………...……1.100V............: <<< Leave
DRAM
DRAM Voltage ……....1.800V............: 2.000V
DRAM Termination .…0.900V............: <<< Leave
Channel A Reference 0.900V............: <<< Leave
Channel B Reference 0.900V............: <<< Leave
I was able to run Prime 95 for about 8 hours stable when the comp stopped responding, I was recording the temps and the highest Cores (0+1) were at 59 and would max at 60. I am wondering if you have any advice.
CPU-Z reports a lower voltage. Anyone have any help for me?
Clock Chip Control
testing as you go
Channel A
Channel B
CPU
overclocking 1.500V
MCH/ICH
DRAM
