Q6600 liquid cooling advice help
tetracore44
53
I got a thermal right ultima 90 and got higher temps with my q6600.(35idle and 47load non overclocked)
i have a B3 but will trade it back to tiger direct(by the way dont buy from them) for a GO. i would like to try liquid cooling and need some advice in parts, i have a 975X chipset if it matters and a budget of around $200 will this be enough to safely overclock it to 4GHz. i dont think ill need gpu liquid cooing as i will keep some airflow in the case. if someone has had good results with a setup i would like to haer about it thanks
So, the only waterblock that you intend on having in your cooling loop is for the CPU right? and you want to try and build that with a budget of no greater than $200?
OK if i cant do it with this mobo im going to trade mine for a e8400 of a e8500. what mobo would be good for this and has raid,pci express possibly sli?
If you said SLI, you just limited your choices by a lot...
Instead of looking at dual vidcard solutions, which imo is a waste of money, perhaps you should look into the ASUS P5k-e. It is known to OC to 500MHz fsb (2000MHz effective) and has wide OCing options that makes OCing real easy.
If that runs on x38/48 chipset, which I believe it does, then yes, yes, and yes (2.0). For 4ghz, your only reliable choice is a x38/48 chipset motherboard, with fsb running at 1600mhz natively, and reliably oc to 2000+mhz.
iluvgillgill wrote :
1600FSB can be achieve on P35 chipset not a problem at all!450x8 for the Q6600 im running on.
Check math. :na:
1600mhz fsb won't get you 4ghz.
450x4 fsb is not a speed to count on for p35 chipset. It's hit and miss, and even if it's hit, you'll have voltage and temperature problems. Practically, x38/48 is the way to go for 1600+mhz fsb.
i agree with you dagger.but i just want to point out the chipset is capable of achieving such speed.and since the poster is looking on watercooling.
so a watercooled NB will have no problem of dealing with the heat.but at the end it all depends whats quality on the chipset/motherboard.
Heat is only one of the walls to run into for oc. Voltage is another. Having to run it too high can kill the chipset even if it's still ice cold. The p35 chipset can only do so much no matter how hard you push it.
well as you know im running on air with 425FSB at the moment.and i will push it to the max see what is achievable.maybe this will give a guidance to the poster.but i guess i will have heat problem as i only got the Zalman 9700 LED to cool the CPU,the CPU cooler will give up before i run into any other problems!hehe
That's a good way to go. Push it hard when it's still within the rma period is smart. If it fails, it ought to do so without costing you money. 😀
And I use this cooler, which received a big FAIL in tomshardware bench. After reading the bench, brought it anyway. :na:
http://www.tomshardware.com/2008/02/20/cpu_cooler_charts_2008/page15.html
whats the difference between the e8400 and the e8500?
can you recomend good ram for oc whit the p35
you say the 975x is capable of 4ghz but is it stable and is it possible. is it risky?
how much would water cooling cost for oc the chipset and cpu?
:non:
Yes, that's right, although 4gb is not much of a waste, since ram is dirt cheap those days anyway.
if i get an x38 chipset and plan to upgrade my cpu in 2 years the chipset would be outdated and i could get a better deal buying 2 cheeper mobo rather than 1 expensive on that will be outdated.
if i get the p5k e how high can i oc on a lapped ultima 90 with the e8400
