Morning all, I am fairly new to the OC process, but I have been reading tons and tons and I think I am at a point where I am just not sure where to go next. I can not get OCCT or Prime to run longer than 5 seconds give or take. I can run 3d Vantage and Mark with out issues and it has been stable all day like this.
My set up is:
Ram- 4GB (2X2GB) Patriot EPP 6400LL Series 800MHZ O/C to 926 on 5-5-5-15 2T @ 2.20V, CPUID shows the 926Mhz with 4:5 FSB😀RAM
CPU- Q6600 2400 O/C to 3340 idle 34 degress according to core temp (Stepping B3 Rev G0) Can't run a load to see what the loaded temps are , but CPUID shows 3340 -371 Bus 1484FSB @ 1.488V
Mobo- Asrock 4CoreTwins P35 Bios 1.40 w/ Water Cooled - Swiftech 220 Kit
Bios settings-
RAM- 5-5-5-15 @ 2.20V
CPU- 371 CPU Freq 1.50 CPU Voltage
NB/SB/VTT all set to Auto.
I have played with voltages for a while now.
I had to losen my RAM from 4-4-4-12. To get it to boot properly. Ran MemTest for 2 hours straight with out errors.
but no matter what it wont run a stable test past 2.9Ghz. I can boot fine, and I can use the PC fine, just not sure why none of the tests support the over clock. I can drop core volts to 1.48 and I get the same results.. any ideas? I would like to think I should be able to run at 3.3 or even higher given my temps. My goal is 3.4Ghz
Any advice / replies are appreciated.
Thanks!
Test results from OCCT shows
Core One temp goes from 37 down to 33 in a minute the load shown while tested started at 46% and went backwards???
Core Two temp went from 35 to 33
Core Three temp stayed at 25
Core Four temp stayed at 25
Vcore went from 1.46 to 1.49
3.3V shows 3.24 steady
5.0V shows 5.04 steady
12V shows 12.7X steady
I am not sure what I am missing here.
My set up is:
Bios settings-
Thanks!
