Ok i have my q6600 overclocked to 3.00 ghz (333 x 9) and the lowest possible voltage i can get orthos to run stable at is 1.3000 v. My ram is OCZ platinum ddr2 800 mhz. The memory is running at 1000 mhz @ 5-5-5-18. Is 1.3000v a voltage that wont decrease the life of my cpu by much? Also nothing seems to read my voltages correctly. Coretemp says 1.2875 (which is my default cpu v) no matter what i do, same with RMclock. CPU-z also reads my voltage wrong it says 1.248 v. However when i run prime95 cpu-z drops from 1.248 v to 1.200 v. Not sure if this is correct but if the drop is correct is this an accceptable vdroop? Should i pencil mod my mobo in order to achive a lower cpu voltage? Is pencil modding dangerous?
Edit- after 10 minutes of prime 95 my system became unstable at 1.3000 v... System appears to stable at 1.3065 v im not running prime95 for to long because i am waiting on the arrival of my new heatsink and my cpu is heating up alot.
