Hi there,
Last night I managed to (finally) OC my Q6600 to 3ghz (9 x 333 [4:5 ratio]).
I also managed to run Prime95 for a little over an hour with no errors.
Woohoo.
Now before I ran P95 for that hour my NB overheated and my PC shut itself down.
So I went into the BIOS and lowered the NB Voltage by 3-5 increments (from 1.18 down to 1.144)
and I didn't get any shutdowns or anything when running P95.
I want to know if these voltage levels seem o.k to you guys:
CPU: 1.32
DRAM: 2.110 (2x 2gb Corsair Dominator 4-4-4-12)
NB: 1.151
SB 1.1: 1.111
SB 1.5: 1.500
FSB Term.: 1.396
DRAM VTT: 1.052
CPU PLL: 1.680
I'm a little edgy over these readings due to the fact that my original CPU PLL was 1.535 and my FSB Termination was 1.204. If I try lowering these 2 values will it have a large impact on my system stability?
Also what's the general rule for modifying RAM performance? Is more voltage required for more MHz or is less voltage required for tighter timings?
Thanks for any help in advance.
EDIT:
I forgot to mention that I am using a P45 Maximus II Formula mobo.
EDIT 2:
I manged to get my CPU to 3.2ghz (8 x 400) to get a 1:1 ratio, however, it is pretty unstable now.
To get my comp to run P95 for 1.5 hours I had to greatly increase some voltages and I am now extremely edgy over them.
Before increasing these voltage levels I was only able to run P95 for around 5 - 10 mins.
During these tests I got many blue screens.
Despite the fact that I think my voltage levels are massive, my CPU is actually not getting over 60c when running a torture test, which is good.
Can anyone give me some info here because I've heard of other people running their Q6600s stable on 1.3v or less and mine is not even though it's at over 1.4...
Woohoo.
CPU: 1.32
NB: 1.151
SB 1.1: 1.111
SB 1.5: 1.500
FSB Term.: 1.396
DRAM VTT: 1.052
CPU PLL: 1.680
EDIT:
EDIT 2:
