q6600 w/ TRUE temps
racs
5
Hey i have a q6600 g0 overclocked to 3.0 with a lapped TRUE and lapped cpu...My idle temps range from 36c-40c and 55c at full load, I also have an antec 900 case with ambient temps around 24c...now i know i should be getting lower temps what gives ? ( reseated heatsink many times and applied AS5 )
using the scythe with the true but i replaced it with one of the antec fans and cpu went down 1 degree or so... recording temps with coretemp although realtemp reads 5c less...on idle highest core is 37c lowest being 35c [coretemp]
yea i did the water drop test and the razor blade seemed pretty flat i also switched the position of the HS and i got worse temps...all fans are on high...also on another not my TRUE slides alot i tried the washer mod but i guess the washer wasnt big enough because it still slides, could this be the problem ?
