In the bios, when i installed it was 45C in the bios.
After Updating the Bios to the latest its now 50C in the bios.
EVGA 790i Mobo with only the stock CPU cooler and its like 50C at idle, its warm up here in Queensland, but still.. (Temps 20C-28C Max Indoors)
(note:temps with open case)
I have tried reseating the cooler with no difference..
(although the board can OC its not set to at the moment.)
Nor would I with only a stock cooler.
Any Ideas?
Can someone suggest a great CPU cooler that will fit this board
(due to the cooling pipes surrounding the cpu some won"t fit at all)
I have M9 ThermalTake Case, although those temps are with the case sides off too, I will be installing 3x120mm fans later as well.
ATM it only has 2 x 120mm fans.
Any Ideas?
