Crow001,
What is your ambient temperature?
The Q9650 is a 95 Watt processor which requires at least a decent mid-range air cooler in order to maintain adequate Core temperatures at 100% workload.
I've owned a Q9650 and have built and overclocked several Q9650 rigs to 4.2GHz. To this day, the Q9650 is my favorite Intel processor, in company with the i7 2600K.
Intel's Thermal Specification is "Tcase", which is CPU temperature,
not Core Temperature. Tcase for the Q9650 is 71C:
http://ark.intel.com/products/35428/Intel-Core2-Quad-Processor-Q9650-12M-Cache-3_00-GHz-1333-MHz-FSB
Core temperature is 5C higher than CPU temperature due to the differences in sensor type, location and calibration. Tcase + 5 makes the corresponding Core temperature 76C.
<-- This is your spec.
Here's the full specs for the Q9650:
Core 2 Microarchitecture 45 Nanometer: Q9650 E0 (TDP 95W / Idle 16W)
Standard Ambient = 22C
Tcase (CPU temp) =
71C
CPU / Core offset + 5C
Tjunction (Core temp) =
76C
Tj Max (Throttle temp) =
100C
Intel desktop processors have thermal sensors for each Core, plus a sensor for the entire processor, so a Quad Core has five sensors. Heat originates within the Cores where Digital sensors measure Core temperatures. A single Analog sensor under the Cores measures overall CPU temperature.
Here's the normal operating range for Core temperature:
80C
Hot (100% Load)
75C
Warm
70C
Warm (Heavy Load)
60C
Norm
50C
Norm (Medium Load)
40C
Norm
30C
Cool (Idle)
Core temperatures in the mid 70's are safe.
Your highest temperatures will occur when running test utilities. Temperatures are typically lower during real-world everyday workloads such as processor intensive applications or gaming.
The relationship between Core temperature and CPU temperature is not in the Thermal Specifications; it's only found in a few engineering documents. In order to get a clear perspective of processor temperatures, it's important to understand the terminology and specifications, so please read this Tom’s Sticky:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
Thanks,
CT
