[SOLVED] Quad monitor setup or triple monitor and a tv?
cole.yarbrough04
Commendable
Sep 25, 2018
65
I am struggling deciding between a quad monitor setup and a triple monitor and a tv setup (3rd world problems, yes I know). Which one do you recommend and why?
Depends on what your plans are. If you're a stock trader, then a quad monitor set-up will work. If you're a gamer that plans on sending the signal through to your tv, then the 3 monitor and tv set up will work.
