Question Quadro k2000 and RTX 2060 same rendering build
Feb 24, 2019
HI! I'm upgrading my pc and bought an RTX 2060 card, and i have a spare quadro k2000, could i install them together? I mostly work rendering in 3ds Max with vray or corona, and im thinking to start learning lumion, could having both cards help my work process? Thanks, this is my first post.
Yes, but the drivers may cause issues as GPUs are usually used solo, or are in NV Link, SLI, or Crossfire. There wouldn't be a progress boost because the 2060 would be doing most of the work due to its newer architecture. Probably a 2-5 second boost? What I recommend doing is just installing the 2060 and sell the quadro. Hope this helps.
Reactions: Arc110
Thanks a lot, thats the kind of insight i was looking for.
