Question Quadro k2200 runs at max temp
Jan 25, 2022
So a few days ago i started to see my Quadro k2200 going to 85-86 degrees when gaming. Butt before upgrading my
cpu to an fx 4300 it was pretty cool at around 50-55 degrees, would the new cpu have anything to do with this because i use it with an athlon ii x2 250 stock cooler?
the upgrade in cpu is now allowing your GPU to be pushed a lot more. Unless youre doing some sort of cad work you should probably change out the GPU to a gaming card, anything in the last 7 years will be better then that Quadro card.
Quadro cards are ment for cad work not gaming, while they can game the dont do it very well.
Thanks, i hope the gpu prices drop so i can buy a gtx 1650 low profile
