The would not have "same size pixels in same postions"...
A 20" Standard Definition LCD TV would be able to display ONLY 480 lines of resolution (or 720 if HDTV). A 20" widescreen LCD displays 1680x1050.
TVs do not make good computer monitors, however a computer monitor can make a good TV
You miss my point and make incorrect assumptions.
I was not asking about Standard definition LCD TVs.
I was asking about LCD TVs that claim 1366 x 768 (or just better than 720p HDTV) and their are a lot that do so.
And not all 20" widescreen LCDs are 1680 x 1050 (just the more popular ones or the newer ones), some are 1366 x 768.
Is it possible that they are not really (natively) 1366 x 768 but are say 1280 x 720? (or even 1024 x 800)
If they are natively (ie have 3 rgb dots spaced 1366 across and 768 down), then why would they display text poorer than an LCD that claims 1366 x 768 but doesnt have a builtin tuner.
or are the reviews at fault, and are comparing 1366 x 768 LCDs to 1680 x 1050 LCDs, both at 20", and are complaining that the lower res LCD cannot display small fonts (of course since the first admits its 1366 x 768) without admitting they are comparing two different resolutions.
My big problem is that i cannot find a store that will connect one of these beasties to a pc, next to a similar PC only LCD of the SAME SPECS also plugged into a pc, so i can compare the text readability for myselft instead of relying on incomplete magazine reviews.
I would love to do this, and even bring in a magnifying glass to see if the tv one was using fewer pixels than the pc one, (and thus lying about its native resolution), or was aliasing the pixels on the text (ie forced blur or color correction or just an inability to change color from pure white to pure black in the span of two pixels).
Maybe the TV tuner models come with a VGA interface that does not have the bandwidth to cope with a 60hz 1366 x 768 vga signal so it has artifacts when rapidly changing pixel color on the edges of text.
(the question is then WHY???)
