[SOLVED] Quality difference between 1080p and 1440p
Bradfishh
9
I am building my first PC and I've chosen a 144hz 1440p monitor as my main but I'm looking to buy a second monitor. I found a good deal on a 144hz 1080p monitor but i'm wondering if there is a significant difference in quality compared to a 1440p monitor.
There’s a huge difference in video picture quality. And the noticeable change is highly related to the size of your screen and how close you are to it. For a computer screen a couple of feet away from your body, you can see a difference if your screen is any larger than 27 inches. Might be best if you just go to the comp store and check it by yourself. And if you're intohigh level gaming, 1440p is also commonly used over 1080p.
https://hometheaterreview.com/1440p-video/
https://www.winxdvd.com/resource/galaxy-note4-qhd-vs-4k-uhd-vs-1080p.htm
Reactions: Bradfishh
