QUEL PILOTE POUR UNE RADEON HD 7450 AU LIEU D4AVOIR SUR LE GESTIONNAIRE DE PERIP
the same question in english:
Which driver for a radeon hd 7450 with windows7 64 bits
Actually i just can see for my graphic card " vga standard "!!
Yes i did it but no result with the ati catalyst center
the system doesn't found the graphic card, always says : VGA standard card
no result with the auto detection
the computer is a HP Pavilion , the card works well with W8 but i put W7 to work with my professional soft and since the card becomes a VGA card!!!
i' had try it so
no result
the system said : no driver found for your graphic card
it seems that , under W7, the graphic card is only recognize as standard card and not as what it is : a 7450 radeon
