i pretty much understood the problem with the 3 gb not 4. but i'm kinda confused on some aspects. for example, i installed 4 x 1 gb of memory on my mobo and it shows 3 gb even when it boots up. this is normal? cpu-z also shows the 4th memory slot is empty.
then the 2nd part. i shut down the PC and removed the 4th dimm, all was ok, still 3 GB. then i removed the 2nd dimm and inseted it into the 4th slot (i thought one of the dimms is broken ) and then it said only 2 GB of memory.
also, the memory is 800 mhz standard but wont go at 900 even with a 2,1 V boost and loose timing. from what i could tell the mobo is kinda **** up when comming to high speed memory. should i increase NB voltage?
thanks
thanks
