Review Quest 3S Review: Most of the same thrills as the Quest 3 for $200 less
Thanks a lot for this review and impressions.
It's really hard to get reviews of the few VR headsets as it is, so I really appreciated having one for the cheaper sibling of the MQ3.
Did you give it a try in PC mode? How was the controllers latency and field of response? Would you play BeatSaber in both PC mode and Quest mode? 😀
Man... A revisit of the Index would be fantastic as well. Specially with all the software changes Valve has introduced.
Regards.
Great review man.
One thing you might want to modify if possible is on the specs table do a listing for the 3 and the 3S. Also lower it down on your review so people don't immediately just scroll past just to look at it. 😏
