Can anyone confirm if it's OK to use any 90 degree ATX adapter at the PSU end instead of the motherboard end they are normally intended for? (There's not a lot of space in my ITX case below the PSU sockets and and angle adapter would be much neater solution for the ATX cable)
The particular Cooler Master one I want to use has anti-ripple caps built in so I'm wondering if it makes any difference which end of the 24-PIN cable it's used on. The cheaper no-brand ones are direct pin to pin connectors (with no caps) so I'm confident it makes no difference which end they go - like an extension cable.
I'm just worried their might be some difference with the CM one I'm not aware of.
TIA
TIA
