question about a wireless ac (m.2?) module for GA-X99M-Gaming 5
qt314
Hey, I am looking to build a new computer and got stuck planning out my build,
I need to have a wifi module in my computer, preferably not taking up a pcie lane as I'm building an m-atx system so pcie lanes are limmited. That's why I thought the best option would be to use the solution gigabyte has used on some of their other boards, like the GA-x99-gaming 7 WIFI. On this board you can see they used one of the two m.2(I'm still not entirely sure if that's actually an m.2 slot) slots to install a wifi module.
Now I would like to do the same on the [Gigabyte GA-X99M-Gaming 5], but for this I ofcourse need a wifi module. The only one I could find on that I thought would fit was the [Intel Centrino Advanced-N 6235 Dual Band/Bluetooth].
Now my question is, will this work together? I'm worried it wont as gigabyte specifies the port on the motherboard as an m.2 slot, but intel species their connecter type as mini-pcie. Would any of you know if this works together, and if not, what wireless ac module would work?
