Greetings,
This is more a question about the motherboard audio codec than anything else, so I'm putting it here.
I'm using a Logitech S-220 speaker set (3.5mm) which is plugged in the motherboard I/O and a MXL Studio 1 Microphone (USB) which is plugged into the front panel I/O. I'm also using a Logitech QuickCam Pro 9000 webcam with microphone which could potentially be part of the issue as well. The motherboard is a GIGABYTE GA-880GA-UD3H which has a Realtek ALC892 7.1 audio controller.
Here are links to the items in anyone needs more info:
Speakers: http://www.newegg.com/Product/Product.aspx?Item=N82E16836121014
Microphone: http://www.newegg.com/Product/Product.aspx?Item=N82E16836709013
Webcam: http://www.newegg.com/Product/Product.aspx?Item=N82E16826104074
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444
Whenever I plug in the microphone, the speakers stop working. They come back automatically when the microphone is removed. I'd like to find the reason for this and find a way that I can have both items running at the same time.
My only thought thus far is that my microphone is somehow confusing the integrated audio controller and comes across as a speak connection, nulling the other speakers.
If this is the case, I suppose I'd have to buy a discrete sound card to run my speakers, so that they wouldn't conflict. I'd rather not have to buy anything else though.
Thanks
Thanks
