the case: Phanteks Enthoo Elite
the fan specs: Case PDF Manual pages 20 to 24.
I got my hands on this lovely piece of Chassis and i plan to use it.
the GPUs would have the normal cooling they come with Aorus extreme 1080 Ti 2 way SLI
the CPU would have the EKWB extreme 360 cooling kit on it (have the kit so shame not to use).
i had a huge wish list few months ago and apperently my family took it to heart(and no you can't have them they are MINE... OK fine, the family too, not just the parts).
the radiator will be at the top which still leaves room for 1 more fan next to it.
the case comes with 5 fans already. 1 top, 1 back and 3 front.
plan on removing the drive bays and whatnots that i won't use which leaves an empty wide space of a case.
all the above i already have so no point saying would've/could've/should've and focus on what i am asking please and also thank you for any help one might give.
should i add more fans? or would the fans that come with it be enough?
also how should i set the fans? considering the way my pc will be set as mentioned.
just trying to see the most efficient way to cool a case.
also should i keep the bottom part separate or open it up to the whole case?
one more detail. no limit on budget. so best efficiency regardless of price would be best. if it comes out cheaper that's great but not a factor in any way shape or form.
