D
Deleted member 2720853
Guest
I'm buying a be quiet! Pure Base 500DX case to replace my crappy HP Pavilion pre-built case that has plagued my existence, prompting me to buy this case and "build" my first PC. I was having some doubts about the cooling. The fans that come with it are three Non-PWM 1000rpm 140mm fans, one on the top, rear and front. I was originally planning to move the top fan as an intake to the front to have two as intakes, and use the rear one as an exhaust.
Now I'm planning to also buy two 140mm High Speed (1600 rpm) PWM fans to replace my front fans, and I want to keep the exhaust 140mm always running at 1000rpm. Is it enough to take out the hot air and ensure good airflow or should I get a high speed PWM exhaust as well? My specs on the current pre-built are i7-8700 & ZOTAC RTX 2070 Mini. I'm planning on buying an Z390 Aorus Pro motherboard, and as for the CPU cooler, I'm planning to buy a Thermaltake UX200 ARGB, in case you want to know what kind of heat I'll be dealing with. I'm on a budget with a little extra spent on motherboard.
Should I also place one of the built-in fans on the top as an additional exhaust running at 1000rpm?
Or am I being entirely stupid, and two 140mm 1000rpm intakes & one 140mm 1000rpm exhaust are enough?
