Hi,
So I purchased a miniPC and love it but I have a question. It only came with a tiny 32GB C Drive, and it has an internal Drive Basked where I installed an EVO 250GB SSD. For the most part, I have it set for everything I can to goto the D Drive such as my Downloads, When installing Apps, where possible I switch the Drive letter from C: to D: etc. How ever one area that is taking up a massive amount of data is the "Old Windows Files" which I believe might be the files for where I would need to do a "reinstall of Windows" back to the original or "Factory Install" files, which are located in C:\windows.old. Since this is taking up 18GB of space, almost 1/2 of the total size of the C: Drive which is only 32GB in total. I did a full Copy and Paste of the C:\windows.old to D:\windows.old.
In Avast and I believe possibly CCleaner as well, I have the option to clear these old Windows files out which would simply delete the contents of C:\windows.old, would this be safe todo? If I were to run into an issue and needed to do a Factory Reset, or Reinstall Windows back to the default, is there anyway that I can point Windows to get the files from where I moved them in D:\windows.old or is Windows always going to look in C:\windows.old by default to find these files?
Is there perhaps an Environmental Path I can change which will point the Restore to look at D:\windows.old?
I would really like to reclaim those 18GB's to be used by the actively running Windows and to use that space for installing applications where it is best to leave them on the C: Drive for performance reasons, and I really don't think I will ever need to revert back to the "Factory Install" however, while I say that, the moment I go and delete the files I just know that something will happen and I will need those files, hence the reason I am asking if I can use them from a different location and or point some ENV Variable to get those files from D: instead of C:. I would really like your guys opinion on this. (PS - I am comfortable using Regedit or changing an ENV Variable if that would take care of what I do but I want to be sure that this can be done, and or should be done before I temp fate.
I look forward to your guys advice!
Thanks!
JD
Thanks!
JD
