[SOLVED] Question about clock speed
Sep 17, 2021
8
Ryzen 3 3200g max (boost) core clock is advertised as 4,0 Ghz. here it shows as 4.004,2, Is it normal for it to be a little bit over like that?
about the bus clock, Hwinfo shows it stuck at 100.1 yet in Cpu-z it shows as oscilating between 99.94 and 100.08. I haven't overclocked anything, in the Bios it shows as Auto.
uWebb429
Notable
May 22, 2020
264
96
890
31
It is difficult for software to calculate the Bus Clock speed 100% accurately. Some slight variation is completely normal.
Hook your computer up to an oscilloscope and the Bus Clock will likely be rock solid stable.
