Hey guys, so i'm building my first gaming rig and I've recently come across the negative/positive pressure conundrum. My question is: should I get two low CFM fans (in the 50-70 range) and 2 high CFM fans (100-200 range) my theory is, in doing this it will keep negative pressure flowing through out the case, or am I just reading too much into this and try and keep all the fans in my case around the same CFM? if the latter is so; would the Arctic F12 be pretty good? Last but not least, are the rubberized fan mounting rivets worth getting? I only ask since they are supposedly great at eliminating vibration within the case.
http://www.amazon.com/gp/product/B00NTUJRHK?psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=A2T6N244WTLWGU
ARCTIC F12 - Value Pack (5pc) - 120 mm Standard Low Noise Case Fan
Specifications
Dimensions: 120 (L) x 120 (W) x 25 (H) mm
Fan: 120 mm, 1,350 RPM
Airflow: 74 CFM / 126 m³/h
Bearing: Fluid Dynamic Bearing
Noise Level: 0.3 Sone
Current / Voltage: 0.25A / +12V
Weight: 107 g
6 Year Limited Warranty
Specifications
Weight: 107 g
