Question Question about CPU power supply connector & ASUS Z390 Mobo
Dec 31, 2019
It's my first time doing a build in like 7 years, and I'm a little confused about where to connect the CPU power supply cable. The only place it looks like it would fit is the EATX12v connector on the motherboard in the top left corner. The mobo manual just says it is EATX, nothing about CPU, and the power supply says only one 4+4 pin (there are two bundled together) is needed unless you are overclocking.
I put both in just to see if they'd fit, I haven't turned it on yet, but is the PS connector labeled CPU actually what is supposed to go in there?
Motherboard: https://www.asus.com/us/Motherboards/TUF-Z390M-PRO-GAMING-WI-FI/
Power supply: https://www.evga.com/products/product.aspx?pn=220-G3-0650-Y1
Pictures: View: https://imgur.com/a/EqB1hVI
Any help would be greatly appreciated. Thanks!
