Today i was having this debate with my friends about CPUs and clock speed vs cores, and to say the least its left me pretty confused and i dont know whats right or wrong anymore, i was hoping perhaps someone knowledgeable here would clarify things for me? 😀
The first of the 3 said that if a CPU has 4 cores and its clock speed is say 2.7Ghz, then each of them is running at around 600Mhz and that whenever an application requires more processing power the OS will let the application use a second core, that way it evens out the load and balances it not to lockup the system, and operating systems like Windows 7 and Vista allow a demanding program not optimized to use more than one core to use more (generally this is what i thought, its like my mantra for choosing a new processor in a build)
The second of them said that one of the four cores is 2.7Ghz but the other 3 balance it out when rhe first is overloaded, but that the total processing power isnt divided among the cores 😵
The last one said that a if a CPU is a quad core then then first 2 cores run at 2.7Ghz and the other two are used for turbo boosting to increase the clockspeed when needed
ive spent like the past hour searching up an answer to my question but ive just found people either reiterating one of the 3 above ideas but no definitive answer, that or going into the complexities of how processors work or siding with one cpu brand and saying its better, could someone please clarify to me which is true in layman's term? much appreciated
