[SOLVED] Question about fans and general setup with motherboard
Feb 23, 2019
I plan on building a new PC here very soon and I am doing research to make sure everything goes well when I put it together. I have a question regarding a couple of things.
My Build: https://pcpartpicker.com/list/yCM3D2
Rosewill Fan Manual: https://www.rosewill.com/download/rgbf-s12001_usermanual_a-pdf/
Now, the Rosewill fans that come with the case and the ones I am buying extra are to replace the fans on my AIO. From the manual, I cannot tell that they have separate power (it seems as if they're powered by the RGB hub that it comes with. So since I will be replacing the AIO fans I was wondering if no fans plugged into the motherboard will be okay? I know the H100i plugs into the CPU FAN as a dummy and then you have an option to plug the rad fans into the device itself or the motherboard if I am not mistaken.
man, you have corsair ML series fans on the h100 and you're going to take them off? they're good fans. no fans plugged into MB will be fine since you will have that fan header block. you don't need it but if you want to you can do it that way. why not run them form the MB?
