O Osaidaz Honorable Feb 1, 2015 43 0 10,530 0 Sep 30, 2020 #1 Hi, if I'm playing a game at 120 FPS and my monitor only supports 60-75 hz refresh rate, does this mean that I'm actually playing in 60-70 fps?
0 J jay32267 Illustrious Mar 16, 2017 8,669 834 37,290 1,694 Sep 30, 2020 #2 You are actually seeing the refresh rate of the display.....you aren't seeing the gpu frame rate....unless the gpu frame rate is the same or less. So for instance....with a 60 Hz display....you will never see more than 60 fps.....even if your GPU is capable of more.
0 Rodrigodrt Honorable Nov 21, 2014 647 52 11,290 71 Sep 30, 2020 #3 yep, and thats why vsync exist, if your gpu is rendeing more frames than the monitor can handle, tearing will happen, in wich you get future and past frames at the same time showing on your screen divided by a line
